chris603
#1 Posted : Wednesday, February 15, 2017 7:52:28 AM(UTC)
chris603
Hello,
Hoping someone here has some advice for me. Recently my Samsung top load washer stopped filling during most of the wash cycles.
Here is what happens:
[LIST=1]
  • Power on
  • Fill washer with clothes/detergent
  • Close lid
  • Select wash (Normal is most frequently used)
  • Washer drains tub of leftover water
  • Washer starts to fill/spin tub at same time
  • About 45 seconds later washer stops filling (tub still spins)
  • ~6 minutes later the nF code is thrown because water level hasn't changed[/LIST]Here are the things I have done so far:
    • Pull/clean/replace the intake screens (no issues)
    • Run through the quick tests - all seems good i think?
    • Replaced the water level sensor with one from APP.com (just the sensor, not the hose itself due to time restraints)
    Nothing I have done has changed anything. The washer still starts to fill and then stops. I don't think its the lid switch and here is why, if I set it to rinse/spin it will fill the entire tub (almost overfill) and it will run the entire cycle. I don't think it would run if the lid switch was bad, could be wrong?
    Any help is greatly appreciated. Thanks!
  • Sponsor
    chris603
    #2 Posted : Thursday, February 16, 2017 4:17:36 AM(UTC)
    chris603
    Bumping this, anyone have any ideas?
