hammerman02
#1 Posted : Friday, January 6, 2017 10:26:31 AM(UTC)
hammerman02
Hi,
I'm looking for some help with my Whirlpool ice maker. It doesn't seem to be calling for water. The water dispenser still works. I originally assumed it was the water inlet valve so I replace that. Still no water. I used a jumper wire to cycle the ice maker. It did spin and go through all of the steps. Once it got to the water fill nothing came out. I checked voltage at the inlet valve during the fill cycle and it didn't register.
Anyone have any ideas what I should be looking at next? I even jumped the one of the wires from the water dispenser valve to the ice maker valve just to make sure the line was ok and it worked.
ThatGuy
#2 Posted : Friday, January 6, 2017 2:01:23 PM(UTC)
ThatGuy
The icemaker motor module is the part of the icemaker that turns on the heater, dumps the ice, and refills the ice mold/tray. It could be causing the problem.
The module
Whirlpool 8201515 Icemaker Motor Module - AppliancePartsPros.com
The whole icemaker
Whirlpool WPW10251076 Icemaker - AppliancePartsPros.com
