Janice4926
#1 Posted : Monday, January 2, 2017 1:38:45 PM(UTC)
Janice4926
Hi,
My vegetable drawers keep freezing. I already had a technician come out last year to fix the drain issue - the drawers used to fill up with water. He added an extension to the drain, a common issue with these fridges I guess.
Anyway - now my drawers are freezing. <30 deg F when the fridge is at 45 deg F. Freezer at 6 deg F (bottom drawer freezer).
I pulled the fridge out to clean the coils and a large condensation spot was visible on back of the fridge - near left hand side (when you're looking at the back of the fridge). See photos attached. Could my coils inside be frozen?
Thanks!
Janice4926 attached the following image(s):
Janice4926
#2 Posted : Wednesday, January 18, 2017 5:00:47 PM(UTC)
Janice4926
just took off the evaporator cover and saw a little of ice at the top but nothing serious.
Fan motor shows continuity
Drain line is clear, i poured some water down there and heard it splash through the other end.
i am still lost!
Janice4926
#3 Posted : Sunday, February 12, 2017 4:00:04 PM(UTC)
Janice4926
Posting as a courtesy, it was the fridge temp sensor! located at the top back panel of the inside of the fridge
Janice4926
#4 Posted : Tuesday, February 14, 2017 5:35:17 PM(UTC)
Janice4926
just kidding. now the drawers are back to 30 deg f . :(
Tried replacing the fan too.
