cchunn1
#1 Posted : Sunday, October 16, 2016 3:11:52 PM(UTC)
cchunn1
Hey guys i have spent 3 days trying to figure out what is going on with my washer. Im getting LF codes and Ld codes. I have checked every suggested check there is. hoses, etc. When i put it in manual mode, i checked every single fuction. They all worked fine. But the washer still will not do it on its on. When i try and start it. It just hums. No water comes in at all. But again in manual mode water comes in and everything works. completly confused. haha
ThatGuy
#2 Posted : Monday, October 17, 2016 7:08:40 AM(UTC)
ThatGuy
I suspect it has to do with the pressure switch or pressure dome, or equivalent parts this machine has.
I see the pressure switch is built into this electronic control. W10591280
I would check the tube that comes up to it and I would check for blockages on the other end.
On the old machines dirt, mold, lint, or even clothing could block the pressure dome and stop the pressure switch from sensing a drop or rise in the water level. I'm pretty sure that's what is happening here.
UserPostedImage
cchunn1
#3 Posted : Monday, October 17, 2016 8:04:12 AM(UTC)
cchunn1
thank u for ur time. I blew in the tube from the control board and no restriction. I hate to have to replace the control board but im thinking that is the problem. Not sure though.
