Icemaker is overfilling and water is leaking from icemaker door. The ice maker is located in the top of the fridge and both the inlet valve at the rear of the fridge and the dual valve in the top of the refrigerator have been replaced with no change. Is there an adjustment for water flow on the icemaker, or should I replace the icemaker module? :confused: Thanks.
Thanks for taking time to respond, but the part # on the icemaker is WPW10377151, it looks like this: ![UserPostedImage](http://www.rcappliancepartsimages.com/dbImages/i/00005354/Ice-Maker-Assembly-WPW10377151-01681806.jpg) [IMG]http://s.********************/is/image/Sears/PD_0046_106_W10377151?wid=400&hei=400[/IMG]
I did not know that the icemaker controlled the water level. You have been a great help, thanks.
