Ice maker stopped making ice a couple of weeks ago. The water solenoid appears to be good, if I jumper terminals L and V on the control module water flows into the ice maker. Once filled, the cycle works as expected, ending with a harvest a couple of hours after filling. Once the harvest completes, at the point where water should flow into the tray, nothing happens. If I manually jumper L and V, water flows, and the cycle repeats normally.
I replaced the control module today with a brand new one. No change, still no water flow during the normal cycle. Jumpering L and V will force water flow, and everything works from there until the harvest completes.
What should I be looking for now?
Very interesting. The module should have fixed it. There are cams inside the module that send current to the valve. Basically, they internally connect L and V. Have you jumped T and H to force a harvest and probed V and ground and waited to see if there is a voltage connection to V when it harvests? That would tell you if the internal cams are working properly.
Originally Posted by: cbmserviceguy Very interesting. The module should have fixed it. There are cams inside the module that send current to the valve. Basically, they internally connect L and V. Have you jumped T and H to force a harvest and probed V and ground and waited to see if there is a voltage connection to V when it harvests? That would tell you if the internal cams are working properly. Thanks for responding. There is indeed voltage between V and N during part of the harvest cycle. Voltage, but no water. I jumped L and V after the cycle completed, water flowed as expected. Doesn't make sense.
It sure doesn't make sense. I'm baffled. If jumping voltage to V causes water flow, then the cams internally connecting them should have the same effect. Out of curiosity, what is the voltage you are reading between V and N when the unit harvests and energizes it as if to call for water?
Originally Posted by: cbmserviceguy It sure doesn't make sense. I'm baffled. If jumping voltage to V causes water flow, then the cams internally connecting them should have the same effect. Out of curiosity, what is the voltage you are reading between V and N when the unit harvests and energizes it as if to call for water? Voltage between V and N wavers between 107 and 108 volts. This is with the NEW control module.
Originally Posted by: cbmserviceguy Voltage between L and N? 121/122 volts between L and N
I'm going to go with the new control is defective. You are dropping too many volts. 107/108 isn't enough to energize the valve. That's why it works when you jump line to it directly, but not when the cams connect them. Best answer I got, but I'd say it's the only possibility.
Originally Posted by: cbmserviceguy I'm going to go with the new control is defective. You are dropping too many volts. 107/108 isn't enough to energize the valve. That's why it works when you jump line to it directly, but not when the cams connect them. Best answer I got, but I'd say it's the only possibility. Ok, thanks. I'll see about returning this one and getting another one.
Ok, let us know how it works out so it might help somebody else with the same problem someday. Thanks!
