burritoman
#1 Posted : Monday, August 22, 2016 4:53:48 PM(UTC)
burritoman
Hello,
My washer stops when the cycle reaches spin, then the lid lock begins flashing. Sometimes the washer completes a cycle fine though. If it stops at the spin cycle, I can unplug/replug the power and just run the drain/spin and get through it.
After some research, I found the error code F1 E2. Ran some diagnostics on it. I ran the automatic test a couple times and it passed. I ran manual tests on all functions and it passed. Trying to run calibrate always fails however.
I opened the console and unplug/replug all wires to the control board. That did not fix the problem.
My best guess at this point is either the control board or actuator needs to be replaced. Any help would be greatly appreciated. If I have to replace the control board, I think I'd rather buy a new washer and sell this one as defective. If it's just actuator I may just buy the part and fix it. What do you think?
burritoman
#2 Posted : Saturday, August 27, 2016 12:14:31 PM(UTC)
burritoman
bumpity bump
