]I changed the door lock assembly, and it still is doing the same thing. The sensing light turns of the water stops and and it doesnt spin. Help!
Joined: 6/13/2014(UTC) Posts: 781 ![Man Man](/Themes/yafvision/male.gif) ![United States United States](/Content/images/flags/US.png) Was thanked: 1 time(s) in 1 post(s)
Good evening Bulldog21! Can you give us the model number please? Also what was it doing before you changed the door lock assembly?
Model FAFW3801LW5 its doing the same thing it did before water comes out for 2 sec stops the water and it doesnt cycle and the power is still om
Are you receiving any error codes?
Yes i took it apart today and in the manual was inside the washer. So u press 2 buttons to get the error code and it was error 31. So i looked it up and it says it can be the the pressure sensor or the control board so im going to exchange the door lock assembly for the pressure sensor tomorrow thanks
