My microwave when I turn it on, will not work at all. When I try to turn on microwave the fuse blows out. I tried to fix this problem by changing the fuse in the microwave but the same issue is still happening. When I took out the microwave, I found out that the stirrer blade/antenna/ part 58001197 inside the microwave is broken. Could this be the reason that is making the fuse blow out? I have tried for looking for the part but the part is no longer made/continued.
Thank you.
This is the Internal microwave issue and for this you have to contact appliance repair company, because this issue can not be solve out by trying at home. It needs professional and trained appliance technicians.
