Brian Ramsden
#1 Posted : Saturday, February 16, 2008 7:22:29 PM(UTC)
Brian Ramsden
The dishes in my hotpoint dishwasher won't come clean. One suggestion I have seen is to clean the washe arm. I can't get it off. I also can't find a manual or diagram to help. It has a wash tower but no visible way to loosen it to get to a screw to remove the washer arm. All the sites I have visited (Hotpoint and Camco plus other repair sites) do not even recognize my model number. I don't know what to do. Please help if you can.
richappy
#2 Posted : Sunday, February 17, 2008 2:05:02 AM(UTC)
richappy
Check the water level, should be just below the heater, if ok, open the door a few times and check for water spray from the lower spray arm and also check that it is turning. If poor spray, twist off the tower above the lower wash arm, i think you turn it counterclockwise. Use a large adjustable pliers to do this.Then check under the wash arm for a worn gasket.
Also, remove the rear tub pump cover and check for blocking items at the pump inlet.
Hotpoint dishwasher not working (Dishwasher Repair)
by Guest 7/25/2022 1:43:03 PM(UTC)
Older Hotpoint Dishwasher not Cleaning (Dishwasher Repair)
by Polly147 8/23/2015 3:04:31 PM(UTC)
Hotpoint Dishwasher (Dishwasher Repair)
by HunterChase 1/31/2014 1:11:52 PM(UTC)
Hotpoint Dishwasher leak (Dishwasher Repair)
by stranger12 12/23/2012 1:15:12 PM(UTC)
Hotpoint dishwasher leaking from bottom of motor (Dishwasher Repair)
by Beacon18 10/1/2012 10:45:36 AM(UTC)
HotPoint dishwasher stopped working (Dishwasher Repair)
by miklik 8/30/2012 12:18:10 PM(UTC)
hotpoint dishwasher (Dishwasher Repair)
by kleet2310 2/15/2012 2:03:19 PM(UTC)
by Robert Humphrey 12/29/2011 6:52:35 AM(UTC)
Hotpoint Dishwasher Timer Problem (Dishwasher Repair)
by james.hood@yahoo.com 2/13/2011 4:32:30 PM(UTC)
HotPoint Dishwasher draining intermittently (Dishwasher Repair)
by coomerguy08 2/12/2011 5:11:10 AM(UTC)
Hotpoint dishwasher won't drain (Dishwasher Repair)
by OneEye 1/18/2010 2:02:21 PM(UTC)
Older Hotpoint Dishwasher (Dishwasher Repair)
by benderra 1/15/2010 10:00:39 AM(UTC)
Hotpoint dishwasher not Draining (Dishwasher Repair)
by FoByFo 1/6/2010 4:59:00 PM(UTC)
Hotpoint Dishwasher HDA750S-45BA Drain Solenoid (Dishwasher Repair)
by tjones829 4/20/2009 6:13:45 PM(UTC)
Hotpoint Dishwasher Makes Buzzing Noise, Won't Drain (Dishwasher Repair)
by gwolfson75287 4/9/2009 8:12:26 AM(UTC)
