evs90
#1 Posted : Monday, January 25, 2016 4:48:48 PM(UTC)
evs90
So i just bought a used samsung dryer model DV448AEW/XAA that i needed to put and extension to in order to reach the plug on the wall. i crossed the neutral with one of the side ones by mistake.... i connected the dryer to the wall and started it. It turned on for a few seconds and then it turned off. I fixed the crossed wires but now it wont turn on. Does it have any kind of fuse? Or i just burnt the module?
#2 Posted : Tuesday, January 26, 2016 6:10:56 AM(UTC)
I cannot sat what is the problem.
You will probably need a wiring diagram/tech sheet to figure it out.
I cannot find one.
Check inside the unit or on the back to see if it is there.
Even if it is a fuse that blew you have to figure out what is blowing it.
The initial miss wiring doid not blow it as it did come on after you did that.
evs90
#3 Posted : Tuesday, January 26, 2016 7:05:03 AM(UTC)
evs90
What would be the first thing to burn when something like that happens? Do you think that checking for power getting to the module and see if theres power after the module would tell me if the module is good or bad?
#4 Posted : Tuesday, January 26, 2016 8:38:10 AM(UTC)
[COLOR="Blue"]What would be the first thing to burn when something like that happens?[/COLOR]
The control board
[COLOR="Blue"]Do you think that checking for power getting to the module[/COLOR]
I would start by checking power into the unit and then for power at the board.
[COLOR="Blue"]
and see if theres power after the module would tell me if the module is good or bad?[/COLOR]
To know what power would be where you need a wiring diagram.
Below is a link take a look in the Dryers manuals section. Look at a couple of the Samsung's. This will at least give you a clue how Samsung does things.
You will have to join the site and be logged in to be able to download.
