I sent a post but forgot to send Model# But my question was when my washer fills up with water it's supposed to be a large load but looks like a small load. Is there any way to adjust the water level?
Not really, trying changing out the water pressure switch, and make sure the hose to it from the tub is clear and there are no obstructions. We never try to work on pressure switches since if they malfunction it will flood your house, maybe even destroy it.
If the water level switch changeout does not fix things the timer may be the issue.
