alyuka
#1 Posted : Wednesday, January 13, 2016 5:20:40 PM(UTC)
alyuka
I am down to only one of the cycle buttons (heavy, normal, Eco, etc) working. These are all on the left side of the touch pad. Every button on the right side of the touch pad works. Theses are the options for drying, sani rinse, top rack only, etc.
I'm not sure what replacement part I need to fix this issue. I've looked at the parts online and there's a control panel, but there's also a housing unit which sits right under the touch pad. Or could it just be the wires? Any help on which part(s) I need would be appreciated.
#2 Posted : Thursday, January 14, 2016 1:53:47 AM(UTC)
Parts for Whirlpool WDT790SAYM0 Dishwasher - AppliancePartsPros.com
Yes it could be any of the three parts you list.
The connecting harness can be checked with a meter.
Unfortunately I cannot find a pinout diagram for the keypad so trouble shooting it will be a pain.
I can tell you that many keys often share a common. So if this common wire goes bad then a number of keys do not work.
Also some keypads use steering diodes so you have to check the keys using both polarities of the meter.
There is also the possibility that the control board itself has a problem.
So I would do the below cleaning of the plugs and receptacles between the keypad and the control board.
Check the harness between the two parts with a meter to be sure it is OK.
If you have patience and some electronic experience you could check the keypad keys with a meter but this may tbe a pain. There is a possibility that you could trace the key tracks on the keyboard to figure out which pin out is which key.
The most likely culprit is the keypad itself.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
alyuka
#3 Posted : Thursday, January 14, 2016 5:26:58 AM(UTC)
alyuka
Thanks for the reply. I'm a noob at this, so can you explain what a meter is? Can it be picked up at a local hardware store?
Thanks.
#4 Posted : Thursday, January 14, 2016 7:07:43 AM(UTC)
It is a volt/ohm meter also known as a multimeter.
It measures ohms, AC volts, DC volts and low amperage current.
It has a digital readout.
Yes they are available at local hardware stores etc.
Below is my standard blurb on meters.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
alyuka
#5 Posted : Sunday, January 24, 2016 8:41:07 AM(UTC)
alyuka
Took my washer apart today and used some electronics cleaner to clean the connectors. Didn't have any luck. Going to order a new control board.
