AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Need Help Verifing Primary Control Board is bad
Hi I have a LG WM2016CW Washer. The specific problem is that the Main Wash water line/valve gets no power, ever. When testing via QC test mode ( main wash ), I get NO voltage on the main wash valve. The other 2 cold valves (prewash & bleach) & hot all work, the cold water Water Inlet Valve Assembly is new. Does this conclude that the PCB is bad and needs to be replaced? Thanks -TD
Yeah, generally speaking when the valve assembly is not getting power when it is called for then when the temp selection in embedded in the control unit the control unit is usually at fault.
Washer Repair
