Tom23
#1 Posted : Wednesday, December 2, 2015 1:20:23 PM(UTC)
Tom23
Maytag MDE5500AZW Dryer. The digital control panel touch pad doesn't light up at all. I have checked the continuity of the 2 thermal fuses and the door switch, which is good. The moisture sensor does not have continuity when tested. The motor seems to spin freely when I spin it by hand. The lint filter was fairly full of lint about 1/4 inch when I removed it. The dryer was working fine. I had put a small load in to dry using the moisture sensor setting. I forgot about it for a while so I decided to dry it for another 10 minutes so that I could hang the clothes and do less pressing. My wife tried to start it today and the control panel touch pad would not light up at all. Any thoughts in what could be wrong?
#2 Posted : Thursday, December 3, 2015 2:08:20 AM(UTC)
Parts for Maytag MDE5500AZW Dryer - AppliancePartsPros.com
Here is a link to a service manual.
You will have yo join the site and be logged in to be able to download it.
http://appliancejunk.com...e&id=67;t=1449140667
The fuses/thermostats should not kill power to the board.
Check te power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
