Pshotts
#1 Posted : Saturday, November 14, 2015 5:22:49 PM(UTC)
Pshotts
Bottom oven works fine. Top oven won't reach temperature (set for 400 and oven thermometers report only 230) and a 30-degree calibration won't fix the problem. Replace control board? Re-set? Any other test/troubleshoot ideas?
#2 Posted : Sunday, November 15, 2015 1:39:45 AM(UTC)
Parts for Whirlpool RBD277PVS02 Oven - AppliancePartsPros.com
I am assuming that the oven shows that it is ready.
Yes it could be the control board but I would check the oven sensor before replacing it.
Below is a link on how to do this, look at 7, 8, 20 and 21.
http://www.applianceaid.com/ele...-range-repair-topics.php
Note that if the unit stays in preheat it could be that one of the elements is bad. Most units switch back and forth between the elements in preheat and bake.
