lauract
#1 Posted : Friday, November 13, 2015 12:53:01 PM(UTC)
lauract
My neither oven was heating properly so I had the elements tested. There was one bad in each oven. I also replaced the long oven sensor in the bottom oven. Both ovens do not get to set temperature still even though the display shows it is preheated to temp. It runs about 75 degrees lower than what it shows.
#2 Posted : Saturday, November 14, 2015 10:27:54 AM(UTC)
Here is a link to an operators manual.
Try adjusting the temperatures (page 15).
If that does not work then odds are that the control board is bad.
