Hi all, my Kenmore series80 model110... washer agitator keeps getting stuck and wont move. Initially i thought that the lid switch was bad and changed it because the machine would not go into the spin cycle. After i changed it everything worked fine for about 1 and a half loads then it did the same thing and wouldn't go into the spin cycle. Upon further inspection i found that the agitator would not move. I tried to turn it by hand and it wouldn't budge. i pulled down the motor and ran it on the floor to make sure that it was good and it worked fine in both wash and spin modes. I also was able to turn the coupler by hand. After fiddling around a bit the agitator suddenly freed up and was moving again. Put it back together and washed a load and it froze again. Is this a bad transmission, clutch or is the brake sticking?
Well it's not a brake problem, and I would say it is a transmission issue but maybe things will continue to work ok. So I would say do nothing and if the problem recurs then we can deal with it at that time.
Good Luck!
Thank you for your clarification. Since I already have everything apart I will just order a new gear case and change it.
Okay good. If you buy the part from this site you can return it if it does not fix the problem.
Ok all fixed. its up and running like a champ again with the new gear case.
Great, glad that fixed it and thanks for updating us, that is very helpful to everyone who reads this forum.
