One morning my fridge was thawing/warming when my wife made breakfast. Up until then I hadn't noticed any symptoms, although she said the ice was slick the night before. We emptied it out.
The lights in the fridge work, and there's no noticeable damage. Nothing in the environment changed (it's in a cabinet). The compressor doesn't kick on and the fans don't move.
The coils were filthy so I vacuumed them out. Previously I had a fridge where the problem was the relay on the compressor, so I replaced that. That didn't solve the problem. I tested the ohms across the compressor and they did look "good" but I didn't write the readings down so I'll do that again. Trying to follow the logic chain, I replaced the thermostat in the refrigeration compartment but I expected it would kick on the compressor and that didn't happen. I'm thinking it must be a control board or a bad compressor, but if it was a bad compressor then I'd expect that fans would still blow when the thermostat called for cooling, right?
Should I replace the Defrost Control Board or the Electronic Control Board? They are both spendy and I don't see any damage to the board or caps. I'd like to fix this without calling a tech but maybe I should just bite the bullet. Tips would be appreciated, especially if accompanied by suggested tests with my multimeter.
Thanks!
Jason
Parts I've already replaced to no effect -
Thermostat: 2315562
Start-Device Combination (start relay and overload): W10189190
Here are your parts Parts for Maytag MSD2553WEW01 Refrigerator - AppliancePartsPros.comSee the attachment for the tech sheet. Try forcing it in/out of a defrost cycle. If it starts up then replace the defrost board. Out of the two boards I would replace the defrost board first as it is the more likely culprit. Note that ifyou purchase it from AppliancePartsPros you can return it if it does not fix the problem. See their return policy. |
THIS FORUM IS DEAD!!!!!!! |
I will try both the part and, if it doesn't work, the return policy. Thanks!
Please do not order both and then just return one. I do not think that they want to become a parts depot for folks who just order a bunch of parts, swap parts and the return what they do not need. This would end up costing them a ton of money and they would be forced to change the return policy which would be a shame. Most other companies will not let you return electronic parts.
I would get the defrost board first. |
I only ordered the Defrost board because I was sure that was the problem. Nothing has happened for the first few minutes after power on, which is disappointing since I was expecting it to kick on the compressor immediately. I guess it could still be in defrost so I'll give it time. I really don't think it is the electrical control board but maybe that's just because I really don't want it to be that. If the compressor were bad, it would make noise or just be dead but the fans would still run, right? The refrigerator is as silent as a grave.
I did test the pin to pin resistance on the compressor, and R1 plus R2 = R3 so I've read that this would indicate no electrical fault inside the compressor. I guess it could still be a mechanical fault but again, no weird noises.
Any detail on what the electrical control board does that would keep the compressor from kicking on? There's no visible damage to it.
Thanks for you help.
Hopefully your unit has started up. [COLOR="Blue"] If the compressor were bad, it would make noise or just be dead but the fans would still run, right?[/COLOR] Sort of at least the evaporator/freezer fan should run as it is wired in parallel with the compressor. The condenser/compressor fan should also run but I am not sure about this as it seems to be wired into the Taurus board and the wiring is not defined.
If it has not started up I would check the thermostat you replaced. The contacts should be 0s at room temperature. OR You could short the two wires together and then plug the unit in to see what happens. Be sure that the wires have good connection to each other. Also there may be a third wire attached to the thermostat's body, do not disconnect/short thjis as it will be a ground. |
I tried the thermostat short and it didn't start the compressor or fans (although I think I heard a click in the defrost board). I did carefully reproduce the wiring on the thermostat (red, orange and ground) so I'm confident that it was correctly wired.
The only thing I can think that is left is the electric control board, and since that's an expensive part I'm just going to have a professional come take a look at it. I'm baffled that it would be that control board, though; there's no damage or bad solder on it at all. It may be something simple that I'm just missing.
Thanks for your help!
You are welcome. It would have been nice to fix this but I agree with you that it is probably time for a pro. |
