oldebrowndog
#1 Posted : Tuesday, November 10, 2015 11:38:46 AM(UTC)
oldebrowndog
My dryer started going out last week. First it would not heat on the delicate setting then eventually the regular setting also stopped heating.
I tested the temp setting switch, the heating element, the high temp thermostat, the fuses, door switch, and the thermostat on the exhaust air duct. All showed continuity (needle went to 0 ohms).
The only thing I did not test was the timer since I did not know which leads to connect to to test. But it doesn't seem like this was the problem anyway.
Is it possible one of these could test fine but actually be out?
Also does any one know which leads on the timer to touch the multimeter to?
Any help would be appreciated.
#2 Posted : Tuesday, November 10, 2015 12:19:52 PM(UTC)
Parts for Maytag MDE6400AYQ Dryer - AppliancePartsPros.com
Here is a link to a manual.
It does not specifically show your unit but one of the ones in the 6000 series should be close. Sorry but it is the best I can do. The type of temperature switch should help you do this.
You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com...e&id=67;t=1447189294
[COLOR="Blue"]Is it possible one of these could test fine but actually be out?[/COLOR]
No
[COLOR="Blue"]
Also does any one know which leads on the timer to touch the multimeter to?[/COLOR]
Use the wiring diagram.
Sorry to even complicate things further but the following may also apply to your unit, see the attachment.
The loosing delicate first does point to the timer or the temperature switch.
One thing I would check before proceeding is the power. the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
If OK I would set the unit to high heat timed dry that should be the simplest heating circuit path.
oldebrowndog
#3 Posted : Wednesday, November 11, 2015 6:08:24 AM(UTC)
oldebrowndog
Thanks for the help. I'll give these things a test and see what comes of it.
