terricapps
#1 Posted : Friday, October 9, 2015 5:29:33 PM(UTC)
terricapps
Washer will only fill. Makes no sound whatsoever. I have tested the lid switch and the cord. The wall socket works because the washer fills. I performed a timer test [not the hot test though] and it passed. It is almost as if there is a reset button somewhere but I don't believe there is. Any suggestions?
terricapps
#2 Posted : Friday, October 9, 2015 6:19:40 PM(UTC)
terricapps
correction: I tested the push-pull switch of the timer, not the timer itself.
