I have a ge washer that with no warning quit spinning, I also have seen no light, even though manual says there is one. Per wiring diagram agitator is dk blue and white, blue has power white never powers up when time to spin. The motor doesn't make no noise light up or smell burned. Weird thing is line with fuse stays hot on motor side of link and no power of timer side of link. I tried jumping link and it killed juice to line until I unhooked it again, not sure if related .?..? Not sure how to check timer, or is no light same as dead motor? Oh and the lid switch checked out fine. Thanks for your time,!
