I was going through the paces and had to jump the connector to bypass the emitter go get my ice maker back in business.while waiting for parts. I was very stupid and jumped the wrong 2 wires and caused a spark that burned the connector and made one of the wires come out of its slot. The female connector that came out of the slot is now malformed, so it won't go back in, and I need to replace that female part of the pin connector and possibly the connector itself because it got a little charred. Ideas? Help! Here is a link to the best picture I could take with the limited amount of room: https://app.box.com/s/ak...8wwcwrwel7epnsxqmfpt4hv7
Anyone know what kind of connector it is and can I get the parts? Anyone?
Here are your parts Parts for KitchenAid KSRB22FKSS00 Refrigerator - AppliancePartsPros.comIs it part of Item 32 in Section 11, see below. Click on the pictures for more views and info. Part number: AP5176630
I doubt you will be able to find the connector as it does not look like a standard electronics connector. You could try Digikey or another electronics supply house. The other option would be to hard wire it in. You could use small wire nuts so it is at least a little easier to remove/work on. |
THIS FORUM IS DEAD!!!!!!! |
