jaybick
#1 Posted : Monday, August 24, 2015 6:34:15 AM(UTC)
jaybick
Our dryer runs then shuts off after 10 mins? I have replaced the cycling thermostat, what else could be the problem?
#2 Posted : Monday, August 24, 2015 12:41:49 PM(UTC)
http://www.appliancepartspros.c....aspx?model=DBSR453EB2WW
By shut off I am assuming you mean that the motor stops.
Can you restart it right away or do you have to wait several minutes?
If you have to wait then it is probably the motor overheating.
The motor's thermal protect is opening and you have to wait for the motor to cool down so it resets.
Could be:
That the motor is clogged with lint and not cooling.
That there is too much drag on the motor. Try turning it in the correct direction manually. It should turn fairly easily. You may want to try this on a couple other units to get a feel for it. If there is too much drag it could be either the rear or the front drum bearings.
That the motor is on it's last legs.
Dryer Repair Again and Again (Dryer Repair)
by Guest 6/25/2022 3:48:47 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Dryer repairs (Dryer Repair)
by P3FE 10/16/2021 2:36:49 PM(UTC)
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 3/19/2020 12:26:10 PM(UTC)
Dryer Repair Issue (Dryer Repair)
by jdharrin 10/2/2019 1:32:57 PM(UTC)
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 2/2/2018 5:35:41 PM(UTC)
Dryer repair Help! (Dryer Repair)
by Hah45 10/4/2017 2:39:32 AM(UTC)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 12/26/2015 12:03:59 PM(UTC)
Dryer Repair (Dryer Repair)
by sotomargie 12/21/2015 9:44:35 AM(UTC)
Dryer repair (Dryer Repair)
by dchurch 9/26/2015 8:38:17 AM(UTC)
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10/13/2014 10:54:09 AM(UTC)
by Tom Campion 4/14/2014 6:20:19 AM(UTC)
by kencorey281@gmail.com 11/12/2013 2:35:48 PM(UTC)
by fredpeterson543 9/8/2013 9:47:57 PM(UTC)
