Ray F
#1 Posted : 10 years ago
Ray F
The unit stopped working after filling. Timer appears to have plastic dust and does not feel like it is turning and clicking as usual. I am having trouble accessing removing ends on upright panel. I know that I need to unscrew the upright after removing the ends.
fairbank56
#2 Posted : 10 years ago
fairbank56
You don't need to remove the ends of the panel to open it. There are two spring clips under the panel, one at each end. Use a putty knife and slide under the clips to release them and then rotate the panel back. Problem is likely the lid switch. Check for loose screws on the left side lid hinge. This hinge activates the hidden lid switch. Lid must be closed for washer motor and timer to operate.
Eric
Auto-dry setting timer does not advance (Dryer Repair)
by herseywa 5 years ago
Whirlpool (Roper) electric dryer runs and heats. Timer does not advance in auto or ti (Dryer Repair)
by biomed172 10 years ago
No Heat, Timer Does Not Advance (Dryer Repair)
by MRGETITFIXED 11 years ago
washer tub full spins but water still in timer does not advance (Washer Repair)
by scooty1 12 years ago
Amana Dryer Timer Does Not Advance in Auto Mode (Dryer Repair)
by splehigh 12 years ago
Whirlpool Dryer - No heat, Timer Does Not Advance (Dryer Repair)
by katielove22 12 years ago
NO Heat - Timer does not advance (Dryer Repair)
by JMWITT 13 years ago
Electric Dryer Not Producing Heat & Timer Does Not Advance in Auto Dry Settings (Dryer Repair)
by hifroggyjenn 13 years ago
Maytag gas dryer. Timer does not advance and does not heat. (Dryer Repair)
by lfregia 14 years ago
maytag dryer timer does not advance (Dryer Repair)
by Carbon 15 years ago
Timer does not advance dryer runs no heat (Dryer Repair)
by Rmelc1 16 years ago
Timer does not advance in auto mode (Dryer Repair)
by rman 16 years ago
Timer does not advance in auto dry mode (Dryer Repair)
by Teager 16 years ago
Amana Dryer dries slowly, and More/Less Dry Timer does not advance (Dryer Repair)
by dtshenoy 16 years ago
Timer does not advance (Washer Repair)
by Lloyd Kneller 17 years ago
