Hi APP Pros, The cook top has 5 burners, one of the knob (please picture 1) started to spark/short with cracking sound and smoke and burning smell. This would happen if you try and operate any other knob. Reading the forums, I guess the Harness Switch may need replacement. However, I will appreciate if you could please look at the pictures and advise the parts that I may need to fix this problem. Also do you have the detailed instructions on how to take out remove the top cover to be able to replace the damaged parts. Thanks nj1971 attached the following image(s):
Dear APP,
Could you please respond to this as I need to order the parts asap.
