Washer was working fine, moved to a new house and now it has problems. It does its calibration spins, and adds about a cup or two of water, then nothing. No kinks, it spins a little, water is on, pump appears to work (hard to tell with only a little water). Trouble codes F8-E1 not filing or long fill time, F0-E2 excessive suds (don't understand that as not enough water and no soap added), F7-E7 motor unable to reach target RPM, F7-E6 motor fault. I am leaning towards something became loose during the move or the control board is shot. Suggestions, please. Thank you.
The problem turned out to be the autoshutoff feature in the fill hoses. Somehow they got tripped stopping water from flowing into the washer. Replaced the fill hoses with non-autoshutoff and washer works great.
