burrhead
#1 Posted : Monday, July 6, 2015 7:10:10 AM(UTC)
burrhead
When the selector is set to the "more dry/less dry" area the dryer works correctly but will not stop .There is heat and air flow for the entire time it is running.....5 hours last evening before we realized we had a problem.
Is there a moisture sensor that I do not see?
The timed sections of the control work correctly.Any help is appreciated.
fairbank56
#2 Posted : Monday, July 6, 2015 8:35:18 AM(UTC)
fairbank56
There's no moisture sensor on this dryer. Could be that the power resistor is faulty. Resistor is next to and connected to the timer. Wiring diagram is not listed on the parts list so if you could post a copy of it, I may be of more help to you. Resistor generally reads around 4000 to 5000 ohms.
Eric
Dryer won't shut off in automatic mode (Dryer Repair)
by Elle Dee 4/1/2015 8:08:32 AM(UTC)
Whirlpool dryer won't shut off when clothes dry (Auto Dry Miser) (Dryer Repair)
by tmulroy 11/30/2014 9:12:26 AM(UTC)
GE Profile Dryer Won't Shut Off (Dryer Repair)
by Burger 11/19/2014 4:01:01 AM(UTC)
Whirlpool dryer won't shut off in auto dry mode (Dryer Repair)
by ddavis263 9/11/2014 7:01:31 AM(UTC)
Kenmore Dryer Won't Shut Off (Dryer Repair)
by TOBY1938 7/23/2014 8:42:08 PM(UTC)
Maytag Dryer won't shut off in auto mode (Dryer Repair)
by dkennedy53 3/18/2014 8:34:54 AM(UTC)
dryer won't shut off on any setting and clothing never get even warm (Dryer Repair)
by nwarner0704 1/30/2014 2:27:02 PM(UTC)
Dryer won't shut off - Timer has been Changed (Dryer Repair)
by jthad 11/3/2013 7:04:39 PM(UTC)
Kenmore dryer won't shut off (Dryer Repair)
by Jerrycurl 5/28/2013 3:39:08 PM(UTC)
Dryer won't shut off (Dryer Repair)
by ebb 6/22/2012 4:27:16 PM(UTC)
Frgidaire Gallery dryer won't shut off (Dryer Repair)
by rwild1967 4/27/2012 9:44:38 AM(UTC)
by redruby123 4/4/2012 7:00:06 AM(UTC)
Dryer won't shut off on any cycle (Dryer Repair)
by gfix 11/16/2011 8:38:43 AM(UTC)
by metsmaniac 7/29/2011 8:44:33 AM(UTC)
GE dryer won't shut off in auto cycle (Dryer Repair)
by corlie 2/8/2011 12:59:51 PM(UTC)
