KLS2015
#1 Posted : 10 years ago
KLS2015
Hello:
I have a GE Profile Washer, Model # WPRE6100GOWT. Unit will not fill for Rinse Cycle.
I have replaced the Board (ordered from this site) The swap-out went well...no problems. However, the washer still Stops and will not fill for the Rinse cycle....Cold Water (We fill the tub by hand, then rotate dial to Drain/Spin to complete the cycle.
I tried the Reset --Opening/Closing lid method, with no change in results.
Please Help.
Simon / APP Team
#2 Posted : 10 years ago
Simon / APP Team
Groups: APP Team
Hi.
Will your washer fill with cold water on the cold/cold water setting? If not you may have problem with cold water supply or water inlet valve.
Here is the valve Part number: AP3861119
Thank you,
Simon.
