Get F-7 code and all research says temperature sensor, so $35 later and sensor changed, still get F-7 code. What do I check next?:mad: :confused:
Groups: APP Team
Hi, Barry. You can check the sensor with multimeter for continuity. It should show resistance between 1100 and 1200 Ohms at room temperature. Also, you should measure the resistance again at the main control board plug so this way you are testing the harness too, because often the sensor's connector plug may cause the problem. In case if the tests shows the sensor is good, then most likely the main control board is faulty. The oven Part number: AP4442099
