I purchased a bottle of transmission lubricant (6-0560800) from Applicance Parts Pros and the label has different capacities for a couple of Maytag washer models. I have a model number LAT9520AAQ--can someone please tell me the correct amount of fluid to refill? The last thing I want to do is overfill this unit. Thanks for your help!
Originally Posted by: naabemgr  I purchased a bottle of transmission lubricant (6-0560800) from Applicance Parts Pros and the label has different capacities for a couple of Maytag washer models. I have a model number LAT9520AAQ--can someone please tell me the correct amount of fluid to refill? The last thing I want to do is overfill this unit. Thanks for your help! It is either a large or small helical, or a dependable drive. Large and dependable use 34 ounces, small uses 26 ounces.
With transmission laid horizontal and cover removed, add oil til the level reaches just below the edge of the casing. Install cover and your good to go.
Eric
Thanks for the response. Uses full 34 ounces.
