garywool93
#1 Posted : Thursday, March 19, 2015 9:40:02 AM(UTC)
garywool93
Washer fills normally and agitates but then does not drain or spin. Bailed out the water from the tub - still would not spin. Tried different settings on the timer (i.e. permanent press/gentle/etc.) - does not pump the water out or spin. I'm guessing not motor related as fill/agitate work. Is this the timer failing? Any insights would be helpful. Thanks. This is my son's washer, a poor college student, so we would like to try to repair ourselves if possible!
fairbank56
#2 Posted : Thursday, March 19, 2015 1:25:45 PM(UTC)
fairbank56
Most likely a faulty lid switch. This switch only affects drain/spin cycle. The type of switch on this model is prone to coming apart. They can be glued back together or cinched with a small tie wrap or you can just replace it.
Whirlpool 3949247 Lid Switch Assembly - AppliancePartsPros.com
Eric
garywool93
#3 Posted : Saturday, March 21, 2015 12:22:56 PM(UTC)
garywool93
Thank you for the quick response.
we purchased the lid switch and installed it and the washer is working again.
My son and I appreciate the forum.
Whirlpool top load washer won't drain or spin. (Washer Repair)
by Owie55 3/6/2015 1:21:47 PM(UTC)
GE Front Load washer won't drain or spin (Washer Repair)
by rmgaris 2/8/2014 8:15:28 PM(UTC)
GE Washer won't drain or spin (Washer Repair)
by JenNC 1/30/2014 12:52:31 PM(UTC)
roper washer won't drain or spin (Washer Repair)
by Mr.Stormcrow 1/23/2014 10:03:40 PM(UTC)
Kenmore washer won't drain or spin (Washer Repair)
by jpaw24 11/11/2013 6:40:40 AM(UTC)
Kenmore 70 series washer won't drain or spin (Washer Repair)
by ImSR 10/12/2013 8:49:49 AM(UTC)
by Karen.Smith 3/18/2013 12:01:38 PM(UTC)
KitchenAid Washer won't drain or spin (Washer Repair)
by MSUMOM 3/14/2013 7:25:53 PM(UTC)
GE Front Loading Washer Won't Drain or Spin (Washer Repair)
by gblotter 2/8/2013 8:23:32 PM(UTC)
by smyrnaref 8/5/2012 11:06:04 AM(UTC)
whirlpool washer won't drain or spin, lid switch OK (Washer Repair)
by trip2012 6/18/2012 7:38:38 AM(UTC)
by helpplease911 4/3/2012 12:16:26 PM(UTC)
washer won't drain or spin in gentle mode (Washer Repair)
by Frub 5/8/2011 7:17:11 AM(UTC)
by bethandgil 4/12/2011 5:05:27 PM(UTC)
by sissy25 1/7/2011 1:13:30 PM(UTC)
