SEMIFAST0
#1 Posted : Sunday, March 15, 2015 9:00:11 AM(UTC)
SEMIFAST0
Replaced the heat element to start, worked great for 3 loads. Then no heat, everything works but no heat. Element test show continuity, as does the resistor attached to the element metal shell. everything has been removed and cleaned first time around, no blockages. ?? help
#2 Posted : Monday, March 16, 2015 3:29:43 AM(UTC)
Parts for Frigidaire AEQ6000ES2 Dryer - AppliancePartsPros.com
Here is the units tech sheet
http://manuals.frigidaire.com/p...r/134682200ts_wd_EFS.pdf
First check that the power is OK.
The heater requires the full 240 volts.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
Samsung Dryer no heat (Dryer Repair)
by Guest 10/5/2021 5:41:36 PM(UTC)
LG gas dryer no heat (Dryer Repair)
by Guest 8/15/2021 10:28:45 AM(UTC)
Kenmore model 11060022010 electric dryer no heat (Dryer Repair)
by mike5466 5/1/2020 10:29:22 AM(UTC)
Samsung dryer no heat - 5 possible components? (Dryer Repair)
by sgsiegel 2/11/2018 7:02:33 AM(UTC)
by tombeird 11/8/2017 2:32:42 PM(UTC)
Maytag Atlantic Dryer no heat but everything tests ok (Dryer Repair)
by oldebrowndog 11/10/2015 11:38:46 AM(UTC)
Dryer No Heat.mind boggling! (Dryer Repair)
by andrelaplume 10/10/2015 7:22:06 PM(UTC)
by fhorta 9/28/2015 12:22:36 PM(UTC)
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 6/23/2015 5:54:15 PM(UTC)
hot point dryer no heat and timer doesn't advance (Dryer Repair)
by gooseofdeuce 4/18/2015 8:29:56 AM(UTC)
Gas Dryer NO HEAT/FLAME and possible bad timer? (Dryer Repair)
by noles9399 2/26/2015 10:12:14 PM(UTC)
roper dryer no heat (Dryer Repair)
by chuck vaughn 12/1/2014 1:35:50 PM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
GE dryer no heat or blowing (Dryer Repair)
by Luker1099 9/7/2014 1:39:33 PM(UTC)
