nine
#1 Posted : Friday, February 20, 2015 2:50:58 PM(UTC)
nine
Powers on and door locks when you hold start, but the cycle never starts.
If you hit pause the door doesn't unlock, and the power button doesn't work (you have to unplug power and plug it back in to get it to respond). Door will only unlock manually.
No error codes present, door switch continuity good.
Emptied water pump drain catch (no debris was present)
Problem still persists with MI3 disconnected.
Replaced CCU, but problem still persists.
any ideas?:(
nine
#2 Posted : Tuesday, February 24, 2015 5:21:36 PM(UTC)
nine
for reference:
i removed the MCU pcb from the housing after receiving advice on another forum and found burned traces. Ordering a new MCU.
quarterlbr
#3 Posted : Saturday, January 9, 2016 10:08:20 PM(UTC)
quarterlbr
Would you mind reading my post to see if it sounded like your problem? what you describe is very similar. Thanks.
scottthefixitguy
#4 Posted : Saturday, December 17, 2016 10:26:54 PM(UTC)
scottthefixitguy
If your duet washer won't start its most likely due to a bad part behind the start button.
Here's how to fix it at home for 35 cents: https://youtu.be/N8rz8sclwAg
