slugo2
#1 Posted : Thursday, January 29, 2015 3:35:31 PM(UTC)
slugo2
I had a tech look at the machine and he thought the water pressure switch's diaphram was bad even thought the ohm meter showed it to be good. I purchased a new one and it still overfills does the exact same for whichever setting I select. It's more than should be in the tub. Very close to spilling over. I'm able to blow into the hose and it does not sound clogged.
Did I see somewhere that the hose could have a pin hole in it to prevent the switch from sensing it to be at the proper level?
sidfink43
#2 Posted : Thursday, January 29, 2015 4:18:43 PM(UTC)
sidfink43
Yes, the hose could have a pin hole leak, so go ahead and replace it. A new hose and your new pressure switch should fix this, but check the wiring between the switch and the timer and the connections also.
slugo2
#3 Posted : Friday, January 30, 2015 3:32:13 AM(UTC)
slugo2
thank you for the info.
I've seen the video for a Whirlpool hose replacement. Is it the same way to replace the Maytag washer?
sidfink43
#4 Posted : Friday, January 30, 2015 4:18:22 AM(UTC)
sidfink43
Probably, once the cabinet is open you just disconnect the tubing between the switch and the drum and put the new one on.
GE washer overfills (Washer Repair)
by Shad Blewett 11/9/2013 6:07:54 PM(UTC)
Washer Overfills (Washer Repair)
by mikie67 8/28/2013 7:28:09 PM(UTC)
Washer overfills and will not spin (Washer Repair)
by HerschelD 6/18/2013 4:28:09 PM(UTC)
Washer overfills (Washer Repair)
by Auburn 6/2/2013 9:31:33 AM(UTC)
washer overfills and also turns its self on (Washer Repair)
by scamden40 1/21/2013 11:05:54 PM(UTC)
washer overfills , not sure why (Washer Repair)
by fhorta 1/12/2013 10:05:09 AM(UTC)
GE Washer overfills (Washer Repair)
by sprankles2012 10/5/2012 5:03:01 PM(UTC)
Maytag washer overfills (Washer Repair)
by UmuttaU 9/27/2012 5:16:35 AM(UTC)
Washer overfills the tub and floods the floor (Washer Repair)
by John22307 7/14/2012 7:00:20 AM(UTC)
Maytag washer overfills the water (Washer Repair)
by jaz6420 3/26/2012 5:13:37 PM(UTC)
RCA washer overfills on soak cycle (Washer Repair)
by Skynard213 8/17/2011 6:14:42 PM(UTC)
Dishwasher overfills occasionally (Dishwasher Repair)
by jerry80234 3/12/2011 3:42:19 PM(UTC)
by lanedowns 1/16/2011 7:49:23 AM(UTC)
ge washer overfills (Washer Repair)
by shorthorn 5/28/2010 7:15:54 PM(UTC)
by roosterest 1/1/2010 5:36:34 AM(UTC)
