PecosBill
#1 Posted : Monday, January 19, 2015 7:31:02 PM(UTC)
PecosBill
My Whirlpool washer agitates well on all types of cycles but will not pump or spin even when manually advanced to those functions. There is absolutely no pump or spin action or even a slightest sound? I checked for any loose wiring and found none. I put in a new Lid sensor approx. a year ago and it has been working alright since then. I have looked through the various posts on this site but the specific problems & problem symptoms seem to be abit different. At a loss as what repair & parts may be needed? Thank you
fairbank56
#2 Posted : Tuesday, January 20, 2015 6:19:09 AM(UTC)
fairbank56
The problem is most likely the lid switch. Lid switch only affects drain and spin. You can bypass the switch as a test as per this video. Your switch type is the second one in the video. If that is not the problem, then it's the timer.
Eric
