wrenchwerk
#1 Posted : Friday, December 5, 2014 1:21:49 PM(UTC)
wrenchwerk
just got this machine and am having odd noises. Would like to find exact service manual, but internet search will only come close. The machine is a Whirlpool Cabrio Platinum WTW8500BWO 4.5 cubic foot load capacity. I have found a manual for the Cabrio WTW6200S it appears close but this unit has direct drive with an agitator. Mine has direct drive different wash plate. Otherwise looks very similar. Anyone have crossover info or correct manual? Thanks
sidfink43
#2 Posted : Friday, December 5, 2014 4:05:17 PM(UTC)
sidfink43
Because this is a later model the service manuals that are out there are for older models.
I suggest you contact Whirlpool customer service and tell them that since you are the owner of the machine you would like them to provide you with a service manual. They will caution you that any work you do will void the warranty but you are out of warranty anyway.
This may take some persistence on your part, but keep after them.
wrenchwerk
#3 Posted : Saturday, December 6, 2014 9:08:53 AM(UTC)
wrenchwerk
Thank you for the advice. This actually a two week old unit that has had a service call two days ago. The drain pump makes a loud buzzing when the machine is extracting and the drain pump runs devoid of water. The tech claims it is normal. I say bull, it did not do this for the first ~five loads. I used to service commercial Speed Queen, Wascomat, and Huebsch dryers. Have been servicing all types of commercial building equipment for thirty+ years and get infuriated when companies don't admit their errors. I am quite familiar with the equipment and don't appreciate being snowed by Whirlpool. If this is indeed "normal" they have an engineering problem and need to admit that. Sounds as though the pump motor rotor/impeller is running out of balance? Just need the proper road map for the machine to diagnose and repair.
sidfink43
#4 Posted : Saturday, December 6, 2014 10:23:12 AM(UTC)
sidfink43
Whirlpool has made this model and its earlier incarnations so unnecessarily complex that even factory trained techs cannot diagnose and repair them some of the time. In in that case many just give up, say 'that's the way it is supposed to be' and move on.
I think you will just have to bug the hell out of Whirlpool until they realize it is easier to accommodate you with what you need than to brush you off.
Good luck, and note that all your comments are right on!
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
stacked washer/dryer service manual (Washer Repair)
by Guest 8/13/2023 1:18:07 AM(UTC)
Maytag Neptune MAH5500BWW Service Manual (Washer Repair)
by ort11 4/21/2020 9:05:24 AM(UTC)
Dacor RSD30 service manual (Oven Repair (including Ranges and Cooktops))
by sitano 10/22/2018 10:59:50 PM(UTC)
Frigidaire FGHN2844LF2 Service Manual (Refrigerator & Freezer Repair)
by twodotmike 12/19/2015 6:06:53 PM(UTC)
Need help urgently Please. Need service manual or know how (Refrigerator & Freezer Repair)
by bluefitness 10/30/2015 10:25:48 AM(UTC)
by gschvach 11/30/2014 4:53:25 PM(UTC)
Maytag electric dryer takes too long. Troubleshooting guide? Service manual? (Dryer Repair)
by MargretS 11/2/2014 12:08:03 PM(UTC)
Service Manual Dissasembly Instructions for GE Washer (Washer Repair)
by Apple Repair New Orleans 10/2/2014 9:50:35 AM(UTC)
Looking for Whirlpool service manual (Washer Repair)
by Southern23 8/29/2014 5:44:36 PM(UTC)
Service Manual (Microwave Repair)
by wroutt 6/6/2014 10:31:47 AM(UTC)
Thermador Maint/Service manual? (Oven Repair (including Ranges and Cooktops))
by "D" 10/24/2013 6:59:19 PM(UTC)
Service Manual? (Refrigerator & Freezer Repair)
by SwampYankee 9/7/2013 11:30:30 AM(UTC)
Looking for service manual (Washer Repair)
by eccothedolphin 8/18/2013 11:47:13 AM(UTC)
Need service manual (Washer Repair)
by jimbert@cinci.rr.com 8/13/2013 7:22:13 AM(UTC)
