jemiller33
#1 Posted : Tuesday, November 25, 2014 4:02:02 PM(UTC)
jemiller33
I have a Roper washer that does not agitate. It will spin and drain and fill with water. After starting the machine, it fills with water and then stops, no noise or any movement. The timer will move to the next position, but it never agitates.
I have replaced the lid switch and the Direct Drive Coupler, which the coupler was in good condition.
There are no stray noises or activity.
What could it be at this point???
sidfink43
#2 Posted : Wednesday, November 26, 2014 5:04:54 AM(UTC)
sidfink43
It could be the agitator dogs, so check that but if that were the problem you would hear the motor running and the agitator would move a little bit.
So if the dogs are not the problem take off the cabinet and operate the machine and check to see if the motor is turning during the agitation cycle. If it is not the timer (or the motor switch) may be the issue, if it is turning then the transmission is the likely problem.
Kenmore Washer will not agitate, but it will spin (Washer Repair)
by mjaymadson 8/2/2022 9:37:22 PM(UTC)
Estate washer will not agitate properly (Washer Repair)
by Guest 4/21/2022 8:19:49 AM(UTC)
GE washer will not agitate or spin (Dryer Repair)
by grim509 5/10/2018 8:11:57 PM(UTC)
kenmore washer will not agitate (Washer Repair)
by crawdadcreek 7/29/2015 10:07:27 AM(UTC)
by lizardking508 6/21/2015 12:00:22 PM(UTC)
GE Washer will not Agitate or Spin at times. (Washer Repair)
by jackchis 4/6/2015 4:33:00 PM(UTC)
Ge Washer Will Not Agitate Or Spin (Washer Repair)
by Lmaynard99 2/26/2015 8:51:44 PM(UTC)
Washer will not agitate, or spin (Washer Repair)
by win809doo 5/19/2014 8:19:45 AM(UTC)
Washer will not agitate, spin, or drain (Washer Repair)
by nosinina 4/16/2014 8:42:37 AM(UTC)
Washer will not agitate, but does spin. (Washer Repair)
by Kas23 3/18/2014 2:50:05 PM(UTC)
washer will not agitate or spin (Washer Repair)
by CHERIE KING 2/27/2014 8:16:38 AM(UTC)
by dan mayville 12/23/2013 1:52:45 PM(UTC)
GE washer will not agitate but will rinse and spin (Washer Repair)
by gabemich 11/20/2013 8:35:25 AM(UTC)
Washer will not agitate spin or drain (Washer Repair)
by mdbk 11/6/2013 7:49:14 PM(UTC)
washer will not agitate but will spin out clothes (Washer Repair)
by wolf234 9/23/2013 11:08:26 AM(UTC)
