CAG8R
#1 Posted : Tuesday, November 25, 2014 5:45:35 AM(UTC)
CAG8R
Hello, hoping to get some help. The refrigerator was perfect yesterday, today after loading it up with Thanksgiving Day food, I notice the digital display for temp settings inside the fridge is dead, no display at all. No noise or beep if you press the buttons. The ice/water dispenser is also dead. Here is the strange thing, the fridge and freezer are functional. The ice maker is making ice. The lights come on when both doors are opened and go out when pressed in manually. I have replaced the connector under the freezer door lower hinge as it was corroded, but no help. I have 12.5 VDC going to the dispenser board. I am thinking the main control board is broken, but not positive. Any help would be appreciated.
CAG8R
#2 Posted : Tuesday, November 25, 2014 6:06:15 AM(UTC)
CAG8R
I also would like to verify Main Control Board part number:
WR55X10942
Is this the proper board for my model: GSS27RGMF WW
CAG8R
#3 Posted : Tuesday, November 25, 2014 9:25:33 AM(UTC)
CAG8R
I have now replaced the main control board and it did not help my problem. I did find a blown fuse on the MCB that I removed. I also seen an issue with a ground lead on one of the relays soldered to the board. I looks slightly burnt. I guess I am now onto the dispenser board.
Timbo101
#4 Posted : Thursday, December 4, 2014 3:40:35 AM(UTC)
Timbo101
I am having the same problem with my GE Fridge. Display doesn't work and the water dispenser doesn't dispense but Freezer is fine, fridge is fine, and ice is being mage. I replaced the water filer and the display interface but no resolution. Did you fix it yet and if so, what was the problem?
Guest
#5 Posted : Tuesday, July 19, 2022 2:11:37 PM(UTC)
Guest
Groups:
JRPbTdYb
