dragonflies64
#1 Posted : Tuesday, September 23, 2014 7:07:41 PM(UTC)
dragonflies64
Our oven went dead after while using it. The panel, lights everything is dead. The breaker didn't trip either.
Any ideas?
Thank you,
DeeDee
#2 Posted : Wednesday, September 24, 2014 1:58:40 AM(UTC)
I cannot find any info on this unit using the given model number.
Please check it.
First I would check the power.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Next I would check to see if it has a thermal fuse for power to the control board power supply.
This will be a torpedo shaped device in one of the wires close to the control board.
I cannot say if your unit uses this without a model number that I can look up.
If it has one check it with a meter, should be 0 ohms.
dragonflies64
#3 Posted : Thursday, October 2, 2014 3:35:51 PM(UTC)
dragonflies64
Sorry,
The model number is
RBD305PDQ2
Thank you,
DeeDee
#4 Posted : Friday, October 3, 2014 4:50:48 AM(UTC)
Parts for Whirlpool RBD305PDQ2 Oven - AppliancePartsPros.com
There is a thermal fuse in this unit that kills power to the control board etc. (upper left corner of wiring diagram).
If the power is OK then check it.
With the power off to the unit it should be 0 ohms.
It is shown in section 06 towards the bottom of the list (oven thermal fuse).
It will be in one of the wires close to the control board.
If you click on a part's picture or description a new page will open with more info about it.
If it ios blown replace it then check that the oven temperature and oven fan work OK as they may have caused it to blow.
File Attachment(s):
RBD305.pdf (682kb) downloaded 4 time(s).
Guest (5)
whirlpool double wall oven BROIL on BAKE (Oven Repair (including Ranges and Cooktops))
by Guest 6/4/2023 8:04:00 PM(UTC)
Whirlpool double wall oven lower not heating (Oven Repair (including Ranges and Cooktops))
by mid 5/23/2022 12:46:49 PM(UTC)
Whirlpool Double Wall Oven Dead after Self Clean - Door Locked (Oven Repair (including Ranges and Cooktops))
by cmartin27 1/19/2018 1:24:46 PM(UTC)
Whirlpool double wall oven (Oven Repair (including Ranges and Cooktops))
by PotRoastMan 1/9/2015 6:04:08 AM(UTC)
Whirlpool double wall oven (electric) upper oven not working (Oven Repair (including Ranges and Cooktops))
by JayTeeC 3/11/2014 4:54:07 PM(UTC)
Whirlpool Double Wall Oven (Oven Repair (including Ranges and Cooktops))
by abinosa 6/19/2013 10:34:26 AM(UTC)
Whirlpool Double Wall Oven Fan (Oven Repair (including Ranges and Cooktops))
by bernardv 3/10/2012 9:57:23 AM(UTC)
by myoven 11/22/2011 6:38:55 AM(UTC)
Removing trim and control panel from Whirlpool double wall oven (Oven Repair (including Ranges and Cooktops))
by Lifterfe 4/23/2011 4:10:10 PM(UTC)
Whirlpool double wall oven E6 F2 code, then blank display (Oven Repair (including Ranges and Cooktops))
by jvr888 10/31/2010 7:20:02 PM(UTC)
Whirlpool Double Wall Oven Won't Heat... (Oven Repair (including Ranges and Cooktops))
by DaveinMD 12/1/2009 6:28:08 AM(UTC)
by jledereich 9/22/2009 9:51:35 AM(UTC)
Whirlpool Double Wall Oven D.O.A (Oven Repair (including Ranges and Cooktops))
by JaredB 12/8/2008 6:24:40 PM(UTC)
Whirlpool Double wall oven DEAD after self cleaning cycle rbd306pd (Oven Repair (including Ranges and Cooktops))
by sillyshopper 2/9/2008 8:02:27 AM(UTC)
Whirlpool Double Wall Oven - Top Oven Not Working (Oven Repair (including Ranges and Cooktops))
by bigguy 11/15/2007 7:18:45 AM(UTC)
