Refrigerator running much too cold - turned temp control all the way down - did get some temperature rise (baffle may be working). First thing I want to do is replace the thermistor - but before I take things apart - Where is the thermistor in the refrigerator section??? It is not obvious without disassemble. The parts explosion is useless for finding the part.
Thanks,
Vince
See the attachment for the tech sheet |
THIS FORUM IS DEAD!!!!!!! |
denman,
Thanks - I must be blind as I looked directly at it... I will keep the parts locations diagram in the refigerator file.
Again thanks!
