mrdance123
#1 Posted : Thursday, September 11, 2014 2:56:36 PM(UTC)
mrdance123
Dryer stops early in mid cycle after running just 1,2 or a few minutes, randomly and in streaks. Sometimes runs for days with no problem, then it stops early every time. Dryer can ALWAYS be restarted IMMEDIATELY if I move timer to 'off' then reset it to run again.
After drying stops mid cycle, the timer becomes noisy, continues running, and it advances to the 'off' position very quickly, in any cycle, timed or moisture sensing. From 30 minutes it will go to zero in < 2 minutes.
After this mid cycle shutdown, the start button does not work correctly. Dryer starts, but stops as soon as the button is released. It will continue running only if the button is held down.
As mentioned above, turning the timer to OFF, then setting it to a run position again, allows the dryer to ALWAYS start again immediately. The start button works correctly. But it usually stops again very soon within 3 minutes, the problem repeats. Sometimes, not often, it will complete the cycle. This seems to indicate overheating is not the problem, as it always restarts immediately, sometimes quitting early, sometimes running to completion.
Timer behavior: If you set the timer to run, but never push start, the timer will wait 5 minutes doing nothing, then rapidly run down to zero all by itself, and makes a lot of 'gear' noise like a noisy electrc clock. This also happens if the drying cycle is interrupted (opening the door) and left for 5 minutes, the timer then winds down to zero quickly.
fairbank56
#2 Posted : Thursday, September 11, 2014 3:37:14 PM(UTC)
fairbank56
Sounds like a faulty control board. Expensive but can be returned if it doesn't fix the problem. Board is warranted for one year.
Whirlpool W10116565 Electronic Control Board - AppliancePartsPros.com
Eric
mrdance123
#3 Posted : Monday, October 6, 2014 8:33:47 AM(UTC)
mrdance123
Problem continues after replacing control board.
Dryer still stops intermittently mid-cycle,
though perhaps, not as often as it used to.
The new board is better in this way:
It will enter diagnostic mode. The old board would not.
HOWEVER, the timer now runs much too slowly.
After running for an hour, timer moves only 5-10 minutes.
The dryer could now run all day if not monitored,
it must be turned off manually.
fairbank56
#4 Posted : Monday, October 6, 2014 12:13:20 PM(UTC)
fairbank56
Sorry, I don't really have much else to offer. This is the second time I've heard of the rapid timer movement on these dryers with the EvenHeat boards. The timer motor is driven directly by the board. Wondering if you might have an intermittent door switch? Try jumping it out. Jump the blue and white wires at the switch connector.
Eric
More info. It is normal for these timers to run rapidly when power is applied to them continuously. During normal operation power to the timer motor is cycled on/off. In timed dry cycle, the period should be on for 7 seconds, then off for 113 seconds.
Maybe the dryer is overheating and forcing shutdown? Make sure the internal/external duct work is clear of all lint buildup. Make sure the blower wheel is not slipping on the motor shaft. Clean the moisture sensing strips in the drum. If all checks out and problem persists, try replacing the thermistor.
Eric
mrdance123
#5 Posted : Tuesday, October 7, 2014 11:25:52 AM(UTC)
mrdance123
Thanks for your attention to my symptoms :)
Blower wheel is firmly attached, and no lint clogs found,
air moves freely,
firm air pressure is felt when pressing the outdoor exhaust vent louvers.
If overheating is the problem,
how can dryer always be restarted immediately,
after timer is set to OFF then set to run again?
I still have intermittent shutdown problem in any cycle,
can always restart immediately (not overheated).
Discovered I had reassembled the timer improperly after inspection,
with the motor upside down and gearwheel not meshing to the cam wheel.
It's meant to accept a different sized cam gear when turned 180 backward.
The gearwheel was pressing on smooth a surface of camwheel and timer advanced very slowly while improperly assembled.
Timer is now fixed and running in proper time,
and the normal very fast in diagnostic mode.
Does the thermistor control the drying temperature,
turning on and off the heater?
If the thermistor misbehaved and things got too hot,
won't something else trip and permanently shut down dryer?
I see there are to sensors inside the blower wheel housing.
One is the thermistor?
The other one is thermal fuse?
If that blows it must be replaced?
fairbank56
#6 Posted : Tuesday, October 7, 2014 1:02:23 PM(UTC)
fairbank56
If the thermal fuse blows, the motor would not run. I have seen intermittent thermal fuses though. The internal connection between the fuse and the external terminal where the wires attach can become intermittent. The thermistor is used to regulate the heat by turning the heat coil on/off based on resistance of the thermistor which changes with temperature. Could be that the thermistor is faulty and the control board thinks the dryer is hotter than it really is and shuts down. Turning the timer off and then back on again resets the board so it works again. The sensor bars in the drum are supposedly used only for auto dry cycle. So we are down to faulty thermistor, faulty thermal fuse or an intermittent connection such as door switch, belt switch or wiring connections.
Eric
mrdance123
#7 Posted : Tuesday, October 7, 2014 4:20:55 PM(UTC)
mrdance123
dear Eric,
Is this procedure reasonable to try:
First I believe the thermistor is a very low voltage / low current device.
True?
I want to very carefully short together the thermistor connections while dryer is running, to see if that makes the dryer stop with same symptoms I've been experiencing.
That would narrow it down better for me.
According to service specs, the thermistor should read:
9 ohms at 80 degrees,
2.5 ohms at 140 degrees,
so I assume:
shorted out = 0 ohms = very very hot.
This should not damage the control board I hope.
Normal operation is 20 ohms down to about 2 ohms,
shorted out is not a big change down to zero.
fairbank56
#8 Posted : Tuesday, October 7, 2014 5:14:33 PM(UTC)
fairbank56
No, you should not short the thermistor connections. The thermistor should read 9.2kohms, that's 9200 ohms at 80° and 2.5kohms, 2500 ohms, at 140°.
Eric
mrdance123
#9 Posted : Thursday, November 27, 2014 11:38:06 AM(UTC)
mrdance123
Thermistor was the cause. The plastic coating was gone, exposing the electronic sensor and wiring inside to moisture and dirt. Dryer has worked perfectly for weeks after installing new thermistor. I feel a little foolish for not examining the thermistor sooner, it was so easy to remove and look at it.
Guest (6)
