Cloths come out still wet from final spin cycle, I did tried other spin cycles on the timer and it worked. Now it does not work on either of the spin cycles. Any Ideas?
Dose it spin at all?
Yes it does. The machine goes through the entire cycle but there is some water left in the drum. The day before yesterday we tried it again and apparently it did worked. What could be the problem? A clog somewhere?
I would recommend to remove the cabinet and check the pump and the drain hoses for clog and/or a foreign objects inside. Also check for a foreign objects between the inner and the outer tubs. The outer tub made of clear plastic and you can see through it. These instructions will guide you through the disassemble procedure. Gene.
