dwcountry01
#1 Posted : 11 years ago
dwcountry01
I have a Roper model RS25AWXAL00 and it has worked great for many years until yesterday. The freezer is fine stays at -2 degrees. The fridge is hovering at around 50 degrees but no air is blowing out of vents. I checked the defrost system as per the instructions on this site and everything seems to be working properly. I emptied the unit and let it sit for nearly 24 hours with the doors open and a fan blowing to dry it out. I thought maybe ice was built up in the ducts but obviously that wasn't it. What am I missing? Which fan blows air through the refrigerator section? Any help would be greatly appreciated. Thanks in advance.
David
richappy
#2 Posted : 11 years ago
richappy
You will have to locate the fridg section air return vent, might have an ice jam in it.
