JamesO
#1 Posted : Thursday, August 14, 2014 1:32:55 PM(UTC)
JamesO
I accidentally posted the following on the washer page last April:
Bought a Whirlpool fridge (gold series) about 13 months ago and it has been great; however the past couple of days things have been a little warm. The temp for the fridge is set at 37 degrees and the freezer is set at 0 degrees.
I checked and the inside temp is reading 50 degrees on the top shelf next to the vent and throughout & 38 degrees in the meat drawer. The freezer is reading 5 degrees. There's no blockage of the vents.
What could be causing this?
I got a reply:
(If you want to start troubleshooting check the fan and the components that control it. Your refrigeration is fine, the cold air is just not getting into the refrigerator part.) but was not aware of it.
That problem has been solved:
In the end I called Whirlpool (being that the warranty had just expired a month before), and they said that they would be willing to pay for parts but I had to pay the labor costs. As it turns out the upper cold air circulating fan, located in the upper compartment behind the shelves, had gone bad. After installation and defrost in the fridge, I got my fridge back.
After a couple of months I started to get a noise down in the freezer department. As it turns out it was a continuation of the previous problem... the coil in the freezer had built up frost to the point that the fan was hitting it. Defrosted it as well.
Now:
the fridge is a little noisier than in the beginning;
The freezer is set @ 0 degrees and reads 9-11 degrees, but has a hard time keeping anything frozen (i.e. super soft ice cream, frozen juice thawed, ect.)
AND the ice maker quit working. :eek:
What gives???
richappy
#2 Posted : Saturday, August 16, 2014 2:13:07 PM(UTC)
richappy
Is the condensing fan in the back working. If so, remove the back freezer panel and describe the frost pattern.
JamesO
#3 Posted : Monday, September 1, 2014 1:13:24 PM(UTC)
JamesO
File Attachment(s):
richappy
#4 Posted : Monday, September 1, 2014 4:00:09 PM(UTC)
richappy
You have a refrigerant leak, probably the evaporator seal. If it all leaks out the compressor will get internal damage. Still, It would be about a $400 repair.
Freezer warm fridge section is fine (Frigidaire Professional FPHB2899LF6) (Refrigerator & Freezer Repair)
by bc1016 6/24/2021 8:54:35 PM(UTC)
Whirlpool WRT311FZDW00: Ice buildup in freezer, warm fridge (Refrigerator & Freezer Repair)
by bkbk 9/16/2019 3:42:31 PM(UTC)
Freezer coils/condenser still freezing-over causing warm fridge.Thermostat changed (Refrigerator & Freezer Repair)
by fridge123fr 9/2/2019 9:33:23 PM(UTC)
freezer not freezing /warm fridge.. help! (Refrigerator & Freezer Repair)
by Chickadee 10/8/2016 8:06:02 AM(UTC)
Heater in warm fridge glowed, but now won't (Refrigerator & Freezer Repair)
by ithryn 7/20/2016 6:27:25 PM(UTC)
Condenser fan never runs, related to warm fridge? (Refrigerator & Freezer Repair)
by valsidalv 11/10/2015 7:10:05 PM(UTC)
Maytag Cold freezer/Warm Fridge (Refrigerator & Freezer Repair)
by chris hesselgrave 11/14/2014 7:15:16 AM(UTC)
by Matt_in_FW 7/23/2014 12:43:45 PM(UTC)
Clicking sound & warm fridge (Refrigerator & Freezer Repair)
by gtg932 4/26/2014 4:08:34 PM(UTC)
Warm Fridge (Washer Repair)
by JamesO 4/8/2014 12:35:15 PM(UTC)
warm fridge, cool freezer (Refrigerator & Freezer Repair)
by stavros 3/11/2014 8:01:04 PM(UTC)
warm fridge/cold freezer (Refrigerator & Freezer Repair)
by sillyfilly72 8/18/2013 2:54:51 PM(UTC)
warm fridge and no ice (Refrigerator & Freezer Repair)
by aglazner 8/18/2013 7:06:42 AM(UTC)
Whirlpool Gold Conquest: warm fridge (Refrigerator & Freezer Repair)
by dawydiuk 8/17/2013 9:45:44 AM(UTC)
Can bad defrost thermostat cause warm fridge, cold freezer with icy coils (Refrigerator & Freezer Repair)
by EW23 7/6/2013 3:42:16 PM(UTC)
