ms0674
#1 Posted : 11 years ago
ms0674
Great forum with lots of useful information....
Dryer info:
Roper RGD4440VQ1 gas dryer
Now my problem:
Dryer wont heat up to dry clothes, the drum spins but no heat. The ignitor does not glow, no power to ignitor, coils or flame sensor...
Things tried so far:
1- Checked the continuity of thermal fuse, cycling thermostat, thermal cutoff, and high limit thermostat at the back of the unit...
2- Checked the continuity of the timer, gas coils, ignitor, and flame sensor...
3- Checked voltage to the drive motor, gas coils, ignitor and flame sensor...(With and without the unit running in a timed high heat mode.
4- Checked voltage to door switch.
Results of testing:
1- Thermal fuse was tripped (incomplete circuit).
2- All other components showed continuity.
( Ignitor read approx 119 ohlms (40 ohlms reference according to wiring diagram).
3- Drive motor voltage approx 120 vAC
4- gas coils, ignitor and flame sensor voltage = zero
5- Door switch voltage approx 120 vac
Replaced:
1- Thermal fuse
2- cycling thermostat.
Dont know what to try next. I think the problem might be in the timer since no power is getting to the gas coils, ignitor or flame sensor.
Any help would be appreciated.
Thanks in advance.
File Attachment(s):
Wiring Sheet - W10185979.pdf (336kb) downloaded 1 time(s).
fairbank56
#2 Posted : 11 years ago
fairbank56
I agree, sounds like the timer. Timers on this model are cheaply made and are a common failure item. Timer can be returned if it doesn't fix the problem.
Whirlpool W10185971 Timer - AppliancePartsPros.com
Eric
