nathanstrauss
#1 Posted : Friday, July 25, 2014 3:39:37 PM(UTC)
nathanstrauss
After 4 years of use, the compressor runs constantly for this window A/C unit. Regardless of the temperature and thermostat (which seems to work) the compressor stays on and cold air continues to blow. When I turn the unit off the compressor continues to hum. I have to unplug the unit to shut it off. When I plug back in and try again, same problem. Two questions:
1) which part do i need to replace
2) is it possible to replace it myself
The unit is in a very tight spot and nearly impossible to remove from window entirely - so i'd like to fix if possible rather than replace - assuming i can access and replace the right part without removing entire thing from window.
thank you!!
sharonringer
#2 Posted : Friday, August 8, 2014 9:58:32 PM(UTC)
sharonringer
You have been a member since:: 8/8/2014(UTC)
If you are good with handling electrical work then you should replace the capacitor yourself.
Heat Recovery Ventilator & Systems | Warm Home Ventilation| Ventis
