Dominica88
#1 Posted : Saturday, June 7, 2014 7:01:30 PM(UTC)
Dominica88
Have an Electrolux stacked washer/dryer unit. 220v 50/60hz electric 10.16kg capacity.
Dryer belt shredded but cannot find a part number. Purchased used so I have no paperwork.
I am trying to find a part number of belt that I can fix this with.
The belt that came off is about 1/4" wide and has three groves on one side. Looks like a single steel belt strand running along the other side from the groves.
The pieces are well over 200" long, so it must have gone around the drum more than once. The motor shaft has two places that the groves belt would fit, but only one of them is against the tensioner.
Any help would be appreciated. Mainly looking for what belt to get and where to get it at.
#2 Posted : Wednesday, June 11, 2014 5:00:21 AM(UTC)
Double check your model number as I cannot find any info on this unit.
Find your model number - AppliancePartsPros.com
Even when I Google it all that comes up are your posts.
If this is a non North American unit then I will not have a way to get info.
Just as an aside I have never seen a belt that goes around the drum twice.
Is it possible that the pieces you have are from two belts?
Dominica88
#3 Posted : Wednesday, June 11, 2014 11:41:09 AM(UTC)
Dominica88
I have triple checked the model number. It is printed very clearly on the door of the dryer with the bar codes. I have not been able to find anything else with the model number. I did find a paper that has the Laundry Center name on it in the bottom. So I looked up the Electrolux Laundry Center and found some info, but not exactly sure it matches.
After looking at the belt more, I think it may not have only shredded into linear pieces, but also same apart in horizontal layers making it much longer that it began with. My next guess is to take a string and measure around the drum and through the tensioner and motor shaft and see how long that is.
The motor shaft does have two places for the belt, but I found on the PDF from Electrolux-Intl.com for the Laundry Center that one side is for 50hz and the other is for 60hz.
Guest
#4 Posted : Friday, September 23, 2022 11:37:53 AM(UTC)
Guest
Im having the same problem. Did you ever get this fixed?
I would love to know.
