Have a kitcheaid side by side model kssc42qms00. It was operational in a home we recently purchased but sitting idle. About 3 weeks ago it was running 'normally' but we powered it down as we moved in. About a week ago the interior was cleaned in preparation for use. Now upon power up (switch behind top panel) all lights come on, all control panels (there are 3 - 4 of them total) power up and stay on except the main one in the fridge compartment (top of interior with temp readouts, adjustments, resets, etc.). It comes on for apporx 2 seconds, beeps twice then goes out. The fan nor compressor come on. This behavior occurs each time and is very repeatable. Can't check for demo mode nor reset as the control panel won't stay one. Any ideas?
Originally Posted by: bmcclu01@earthlink.net  Have a kitcheaid side by side model kssc42qms00. It was operational in a home we recently purchased but sitting idle. About 3 weeks ago it was running 'normally' but we powered it down as we moved in. About a week ago the interior was cleaned in preparation for use. Now upon power up (switch behind top panel) all lights come on, all control panels (there are 3 - 4 of them total) power up and stay on except the main one in the fridge compartment (top of interior with temp readouts, adjustments, resets, etc.). It comes on for apporx 2 seconds, beeps twice then goes out. The fan nor compressor come on. This behavior occurs each time and is very repeatable. Can't check for demo mode nor reset as the control panel won't stay one. Any ideas? Hi, I am trying to resolve exactly the same...I already rebuilt the control mother board for 99.00 dollars, installed and still the same problem persists. Now I just think it could be the Power inverter, but i am doubting on the Compressor as well...I did all the readings on the windings and they are 6.5 to 7 ohm in all of them...and compressor is not shorted. Not sure anymore...maybe this forum could help...
