txtrevor
#1 Posted : Friday, April 4, 2014 8:47:16 AM(UTC)
txtrevor
Kenmore electric range model 790.46769902 niether the bake or broil element will heat. I have changed the control board, both elements and the temp sensor inside the oven and still nothing. What could it be?
#2 Posted : Saturday, April 5, 2014 8:47:24 AM(UTC)
I cannot find a good copy of the wiring diagram for this unit so the below is a bit of a guess.
The Sears parts site seems to show thet one side of each element goes to the control board. The other sides of the elements are tied together and then go back through something (illegible) to the control board. This something mat be a thermal cut-off/fuse. Yoy will have to trace the wires to check this. If there is one then it should be 0 ohms.
frigidaire oven wont heat after self clean (Oven Repair (including Ranges and Cooktops))
by chalooch101 10/14/2019 5:04:21 AM(UTC)
Oven wont heat or broil (Oven Repair (including Ranges and Cooktops))
by artpell 12/25/2014 1:04:08 PM(UTC)
GE Profile electric single wall oven wont heat (Oven Repair (including Ranges and Cooktops))
by PRWATTS 8/28/2014 8:31:49 PM(UTC)
Oven wont Heat up (Oven Repair (including Ranges and Cooktops))
by belliemom 2/28/2014 5:20:18 PM(UTC)
by cullough22 1/11/2014 6:35:17 AM(UTC)
Kitchenaid Gas oven wont heat up (Oven Repair (including Ranges and Cooktops))
by Travelguy 1/1/2014 5:52:03 PM(UTC)
Oven wont heat up (Oven Repair (including Ranges and Cooktops))
by shellyrodriguez 11/23/2013 8:55:12 AM(UTC)
sears/kenmore elements/oven wont heat (Oven Repair (including Ranges and Cooktops))
by KERMITT454 7/19/2013 4:51:23 PM(UTC)
Maytag Gemini Oven wont heat (Oven Repair (including Ranges and Cooktops))
by Stevewk 5/15/2013 3:12:12 PM(UTC)
Frigidaire Oven Wont Heat Up (Oven Repair (including Ranges and Cooktops))
by GHog 5/7/2013 3:18:52 PM(UTC)
ge wall oven wont heat up (Oven Repair (including Ranges and Cooktops))
by henson1166 1/5/2013 5:08:07 AM(UTC)
Roper electric oven wont heat (Oven Repair (including Ranges and Cooktops))
by fireguy 12/20/2012 7:43:38 PM(UTC)
oven wont heat burners work (Oven Repair (including Ranges and Cooktops))
by michellem 10/2/2012 3:59:41 AM(UTC)
Xfe361lvb Oven Wont Heat,no Error Codes (Oven Repair (including Ranges and Cooktops))
by awvufan76 9/12/2012 10:10:51 AM(UTC)
lights come on oven wont heat up (Oven Repair (including Ranges and Cooktops))
by fxe81hd 5/3/2012 12:43:28 PM(UTC)
